Customizing About page and other pages
The discussion revolves around customizing the About page and other special pages in Discourse, such as FAQ, ToS, and Privacy. Customizing the About page is currently not possible.
Shrike suggests that the About page should be customizable, allowing for long text with markup, removal of the automatically created list of admins and moderators, and the ability to add links to other pages in the hamburger menu.
zogstrip suggests using the description site settings to add content to the About page, but Shrike notes that this is limited and only allows for plain text.
tophee and O.C also express interest in customizing the About page, with tophee finding a workaround using CSS to add text to the page. However, this method has limitations, such as only allowing plain text and the potential for ember identifiers to change.
dax notes that ember element IDs are dynamic and cannot be targeted using their ID.
There’re some special pages in Discourse: About, FAQ, ToS, Privacy. All of them can be changed except About.
I like the idea to have some fixed standard pages in every forum. But why About cannot be customized?
What I need for customizing About page:
  • ability to write some long text with markup (images, emails, phones, other website for contacts)
  • remove automatically created list of admins and moderators (can be done via css currently).
Also there’re links to these pages in main hamburger menu. But only for About and FAQ.
I’d like to be able to add links to other pages in this menu.
Then of cause we need an ability to create such (static) pages. Currently it could be just unlisted closed topics, but we still need an ability to add links to the hamburger menu.
I known there’re several plugins for static pages. I tried this one -
https://meta.discourse.org/t/easy-to-use-static-pages-plugin/36280/
But it doesn’t work at all and breaks Admin UI.
I think at least customizing About page is a must-have feature.
「いいね!」 7
I reckon this is not the best UX, but have you tried changing the description site settings with your content?
May I ask why would you want to remove that crucial piece of information?
Have a look here :wink:
「いいね!」 1
Sure, but it doesn’t work. It’s just text for meta in page head. So it’s limited. If you try add more content in that description in Admin/Settings it won’t save (“an error occurred”).
Well, I want to assign some people to be admins but it’s just for a case, I don’t want other people see that they are admins.
Thanks! But I was thinking about adding links into the hamburger menu (not profile):
https://meta.discourse.org/t/adding-a-guidelines-link-to-the-hamburger-menu/56857/3?u=cpradio
「いいね!」 3
Thanks, but not working for me.
「いいね!」 1
Then you are doing something wrong, as it works perfectly on my Sandbox.
I put the code under </head> not header though, so maybe check that.
「いいね!」 2
If I may follow-up on this: I would also like to add some more text and some links to the about page. While it would be great to simply have an html-text field in the settings where I could add this information, I would be perfectly happy to add this via the CSS for nor, but I’m not sure how to do it…
「いいね!」 1
This seems to work as a workaround: This still needs some refinement:
section.about:after {
  content: "additional text on the about page right under the site description";
This seems to work, but I am sceptical because I have had bad experience with those ember identifiers as they can change and I don’t understand when and how:
#ember932 > div > div > section:nth-child(2) {
Ok, this is it (hooking it before the admins section should do the trick):
section.about.admins:before {
I just hope section.about.admins is not used anywhere else…
「いいね!」 2
For reference you cannot target an ember element with the ID (932) because it’s a dinamic number.
「いいね!」 1
Do you know when when these IDs are re-assigned?
I’m not sure, but every time you open a new tab of your forum you might see different IDs (the last time I looked there was about 2 years ago but I think nothing has changed since then). Try to open it in incognito mode or with different browsers.
「いいね!」 1
So I have a way of adding some text to the about page:
But content only takes plain-text. What if I want to add html-code? Say
For more information click <a href="http://some/url">here</a>
「いいね!」 4
Hi @tophee. I’m also interested in how I modify the about page. We have a lot of people visiting our site from elsewhere and we want this to provide an intro about who we are and why we have set up the forum.
Have managed to add in some paragraphs but I cannot style it.
Has anyone else been able to modify the text on the “about” page - even making some text bold and adding hyperlinks?
Thanks
「いいね!」 1
10件の投稿が新しいトピックに分割されました:モデレーターが「会社概要」ページに表示されない
