Hello
The dark theme is activated and marked to be selected but is not showing for users to switch to it what i can do ?
Hello
The theme is selectable on their user profile, from the “interface” tab.
Where do your users try to enable it?
Can you check if you see or do not see the setting on your user page?
Yes the users can select it from the profile but not the the menu in the top side of the forum like instantly.
like here in this forum.
correct this what i mean.
