Dark Theme Not Applied After Wizard Update
A user, balibebas, reported an issue where the Dark theme is not applied after running the /wizard update, despite selecting the Dark theme option. They are running 2.0.0-beta9 and noticed that users with a default interface color setting are not seeing the dark theme.
balibebas also mentioned that there are two “Dark” options listed in the user profile settings, which may be contributing to the issue.
codinghorror asked jomaxro to reproduce the issue, but jomaxro was unable to do so after following the steps provided by balibebas.
jomaxro suggested that the issue may be a corner case, and balibebas agreed, speculating that it may have been caused by running the wizard multiple times and switching themes back and forth.
After running the /wizard and selecting the Dark theme my users are still seeing the light theme. User profile settings show two “Dark” options listed (only one of them changes the theme). Users who had default interface color setting are not seeing the dark theme once activated—they still see the light theme.
I’m running 2.0.0-beta9 after recently updating from beta7 (from which my site was created).
Can you repro this @jomaxro?
If it’s not easy to repro just LMK and I can try a back-up and restore on my end. I’m still relatively early in the audience building process so now would be a good time for me to make some mistakes.
Thanks for all you do. Jeff is the guy who got me using WTFPL for my software. :smiley:
Hi @balibebas, I was not able to reproduce this, no. Here’re the steps I followed:
  1. Created a brand new site.
  2. Logged into site as Admin (user A)
  3. Skipped initial setup wizard
  4. Created a new account as a standard user (user B)
  5. Both user A and user B had the default (light theme) set.
  6. Checked theme settings as user A and saw that Default was set as enabled by default
  7. Ran wizard as user A via /wizard. Left all values as default (entered fake info when required), and set theme to dark.
  8. Checked theme settings as user A and saw that Dark was set as enabled by default
  9. Refreshed site as user B and saw dark theme
I’ll also note that there is only 1 dark entry in the theme dropdown for user B.
Thanks for trying @jomaxro, think we can just assume I hit some corner case somewhere. Looking over the steps you provided the only difference I see might be running the wizard several times and switching back and forth as if the user wasn’t sure what they wanted. Whatever it was hopefully it’ll just vanish as the custom themes code bakes. Cheers and thanks again.
