Duplicate light theme
In the discussion Duplicate light theme, users are experiencing an issue with two Light themes appearing after a fresh install of Discourse. sirideain reports that the first Light theme is enabled but can’t be selected by users, while the second can be selected. Stephen suggests that re-running the wizard may cause this duplication, but sirideain notes that they only ran the wizard once. bts also experienced this issue and suspects that quitting and resuming the setup wizard partway through may have caused the problem.
I just performed a fresh install of Discourse and there is something odd about themes. There are two Light themes. The first is enabled, but can’t be selected by users while the second can be selected by users. The color scheme each uses has a different name as well. Is there a reason for this duplication or should one of the Light themes be removed?
Did you re-run the wizard? I’ve noticed this when the wizard is run again, particularly when the light theme was modified and light was selected in the re-run.
I ran the wizard once.
Weird I just ran into this same thing! Fresh install just in the last couple days.
Also a duplicate color palette listed in the theme settings, one with no default colors showing… (I did not yet add / edit any colors.)
However when I switch to the “Colors” tab only two (Light + Dark) show as expected:
I did not intentionally re-run the setup wizard but I did quit + resume partway through (had to restart after my machine froze). Not sure if that may have something to do with it…
