This is an SQL version of the Dashboard Report for Notify Moderators.
This dashboard report provides a daily count of private messages sent to moderators with a notification subtype notify_moderators
. This insight helps administrators understand periods of high demand on moderators’ attention and could indicate when users are experiencing issues that require moderation assistance.
-- [params]
-- date :start_date = 2023-12-15
-- date :end_date = 2024-01-16
SELECT
DATE(created_at) AS day,
COUNT(1) AS notifications_count
FROM topics
WHERE archetype = 'private_message'
AND subtype = 'notify_moderators'
AND created_at BETWEEN :start_date AND :end_date
AND deleted_at IS NULL
AND user_id > 0
GROUP BY DATE(created_at)
ORDER BY day
SQL Query Explanation
The query works by extracting data from the topics
table – specifically, those that qualify as private messages to moderators within a given time frame. Let’s break it down:
- Date Parameters:
- The query accepts two parameters,
:start_date
and:end_date
, which define the date range for the report. Both date parameters accept the date format ofYYYY-MM-DD
- Selection and Count:
DATE(created_at)
converts thecreated_at
timestamp into a date format and labels it asday
. This allows grouping and counting messages by the day they were created.COUNT(1)
is used to count the number of entries for each day, labeling this count asnotifications_count
- Filtering Criteria:
- The query filters only those entries where the
archetype
is'private_message'
, ensuring we’re looking solely at messages and not at other types of topics. - The
subtype
is restricted to'notify_moderators'
, isolating cases where users notify or request assistance from moderators. - It checks that the
created_at
timestamp of the message is between the specified:start_date
and:end_date
. - Messages that have been deleted (
deleted_at IS NULL
) are excluded from the count to ensure the report reflects only active communications. - Finally, it ensures that the messages are associated with a valid user by confirming
user_id > 0
- Grouping and Ordering:
- The query uses
to aggregate the results by each day within the specified date range. - Then it orders the results chronologically with
ORDER BY day
, making the report easy to read and interpret.
- The query uses
Example Results
day | notifications_count |
2023-12-17 | 3 |
2023-12-18 | 1 |
2023-12-21 | 1 |
2023-12-23 | 2 |
2023-12-26 | 1 |
