This is an SQL version of the Dashboard Report for Notify User.
This dashboard report provides a daily count of the number of times users have been privately notified by a flag on one of their posts.
-- [params]
-- date :start_date = 2023-12-15
-- date :end_date = 2024-01-16
SELECT
DATE(created_at) AS day,
COUNT(1) AS notifications_count
FROM topics
WHERE archetype = 'private_message'
AND subtype = 'notify_user'
AND created_at BETWEEN :start_date AND :end_date
AND deleted_at IS NULL
AND user_id > 0
GROUP BY DATE(created_at)
ORDER BY day
SQL Query Explanation
The query works by extracting data from the topics table – specifically, those that qualify as private messages to users with a subtype of notify_user within a given time frame. Let’s break it down:
- Date Parameters:
- The query accepts two parameters,
:start_dateand:end_date, which define the date range for the report. Both date parameters accept the date format ofYYYY-MM-DD.
- Selection and Count:
DATE(created_at)converts thecreated_attimestamp into a date format and labels it asday. This allows grouping and counting messages by the day they were created.COUNT(1)is used to count the number of entries for each day, labeling this count asnotifications_count.
- Filtering Criteria:
- The query filters only those entries where the
archetypeis'private_message', ensuring we’re looking solely at messages and not at other types of topics. - The
subtypeis restricted to'notify_user', isolating cases where users have been notified about flagged posts. - It checks that the
created_attimestamp of the message is between the specified:start_dateand:end_date. - Messages that have been deleted (
deleted_at IS NULL) are excluded from the count to ensure the report reflects only active communications. - Finally, it ensures that the messages are associated with a valid user by confirming
user_id > 0.
- Grouping and Ordering:
- The query uses
GROUP BY DATE(created_at)to aggregate the results by each day within the specified date range. - Then it orders the results chronologically with
ORDER BY day, making the report easy to read and interpret.
- The query uses
Example Results
| day | notifications_count |
| 2023-12-17 | 1 |
| 2023-12-18 | 1 |
| 2023-12-21 | 1 |
| 2023-12-23 | 1 |
| 2023-12-26 | 1 |
