Dashboard Report - Time to First Response
This is an SQL version of the Dashboard Report for Time to First Response.
This dashboard report provides insights into the average response time to topics within a specified date range. The report calculates the time taken for the first reply to be posted by someone other than the topic creator.
-- [params]
-- date :start_date = 2024-01-01
-- date :end_date = 2025-12-31
-- null category_id :category_id
-- boolean :include_subcategories = false
-- null user_id :user_ids
-- Time to first response by date
SELECT
  t.created_at AS "date",
  CAST(AVG(t.hours)::numeric(10,2) AS float) AS "response_time_hours"
FROM (
  SELECT
    t.id,
    t.created_at::date AS created_at,
    EXTRACT(EPOCH FROM MIN(p.created_at) - t.created_at)::float / 3600.0 AS "hours"
  FROM topics t
  JOIN posts p ON p.topic_id = t.id
  WHERE
    t.created_at >= :start_date
    AND t.created_at < :end_date
    AND t.archetype <> 'private_message'
    AND t.deleted_at IS NULL
    AND p.deleted_at IS NULL
    AND p.post_number > 1
    AND p.user_id != t.user_id
    AND p.post_type = 1  -- Regular post type
    AND EXTRACT(EPOCH FROM p.created_at - t.created_at) > 0
    AND (:category_id IS NULL OR
         CASE WHEN :include_subcategories THEN
           t.category_id IN (
             WITH RECURSIVE subcategories AS (
               SELECT id FROM categories WHERE id = :category_id
               UNION
               SELECT c.id FROM categories c
               JOIN subcategories sc ON sc.id = c.parent_category_id
             SELECT id FROM subcategories
         ELSE
           t.category_id = :category_id
         END
    AND (:user_ids IS NULL OR p.user_id IN (SELECT unnest(string_to_array(:user_ids, ','))::int))
  GROUP BY t.id
) t
GROUP BY t.created_at
ORDER BY t.created_at
SQL Query Explanation
This report measures how quickly topics receive their first meaningful response by:
  • Calculating response time: For each topic, finds the first post that:
    • Is not from the original topic creator
    • Has a post number > 1 (not the initial post)
    • Is a regular post (post_type = 1)
    • Was created after the topic (positive time difference)
    • Hasn’t been deleted
  • Grouping by date: Aggregates these response times by the date the topic was created
  • Results show:
    • “date”: The date topics were created
    • “hours”: Average time (in hours) until the first response for topics created on that date
  • Exclusions:
    • Private messages are excluded
    • Deleted topics and posts are excluded
    • Self-replies are excluded
Parameters
  • :start_date (date) - format of YYYY-MM-DD
    • Starting date for the report period
    • Only topics created on or after this date will be included
  • :end_date (date) - format of YYYY-MM-DD
    • Ending date for the report period
    • Only topics created before this date will be included
  • :category_id (category_id, nullable)
    • When provided, filters results to a specific category
    • When null, includes topics from all categories
  • :include_subcategories (boolean) - Default: false
    • When true AND a category_id is provided, includes topics from all subcategories
    • When false, only includes topics from the exact specified category
  • :user_ids (user_id, nullable)
    • When provided, only includes responses from specific users
    • When null, includes responses from all users
    • Can accept multiple user IDs as a comma-separated list
Example Results
date response_time_hours
2023-11-12 29.87
2023-11-13 81.52
2023-11-14 5.17
2023-11-15 6.51
2023-11-16 7.75
