Hi Discourse !
I was wondering how you calculate the time to first response in your reports.
Based on what collection from your DB ?
Thank you for your time ![]()
Jeanne
Hi Discourse !
Jeanne
Time to first response is calculated by subtracting the value of the topic’s created_at field from the value of the created_at field of the topic’s first reply. The first reply is the first post in a topic that has a post_number greater than 1 and has a post_type of 1. (a post_type of 1 is used to indicate that a post is a ‘regular’ post, and not a small action, moderator action, or whisper post.)
@simon thanks for your answer.
I am using the data explorer plugin. Do you know in what table I can find this field_first reply ?
I search for it but in vain ![]()
Many thanks
Jeanne
There isn’t a field in the database for this. Discourse uses a method that’s called on the Topic class to calculate the time to first response. You can see the code for it here: discourse/app/models/topic.rb at main · discourse/discourse · GitHub.
This is approximately the SQL query that is generated by the time_to_first_response method. It can be run as a Data Explorer query:
SELECT t.id AS topic_id, AVG(t.hours)::float AS hours, t.created_at
FROM (
SELECT t.id, t.created_at::date AS created_at, EXTRACT(EPOCH FROM MIN(p.created_at) - t.created_at)::float / 3600.0 AS hours
FROM topics t
LEFT JOIN posts p ON p.topic_id = t.id
WHERE t.archetype = 'regular'
AND t.deleted_at IS NULL
AND p.deleted_at IS NULL
AND p.post_number > 1
AND p.user_id != t.user_id
AND p.post_type = 1
GROUP BY t.id
) t
GROUP BY t.created_at, t.id
ORDER BY hours DESC
