Error de migración de base de datos cuando la reconstrucción del launcher funciona
Hola. Intenté actualizar mi instancia de Discourse autoalojada usando launcher rebuild app. El comando termina con un error de migración de base de datos y el foro no se inicia. ¿Qué puedo hacer para arrancarlo? Este es el texto de la consola:
rake aborted!
StandardError: An error has occurred, this and all later migrations canceled: (StandardError)
ERROR:  relation "voice_rooms" does not exist
/var/www/discourse/vendor/bundle/ruby/3.4.0/gems/rack-mini-profiler-4.0.1/lib/patches/db/pg/alias_method.rb:109:in 'PG::Connection#exec'
/var/www/discourse/vendor/bundle/ruby/3.4.0/gems/rack-mini-profiler-4.0.1/lib/patches/db/pg/alias_method.rb:109:in 'PG::Connection#async_exec'
/var/www/discourse/vendor/bundle/ruby/3.4.0/gems/mini_sql-1.6.0/lib/mini_sql/postgres/connection.rb:217:in 'MiniSql::Postgres::Connection#run'
/var/www/discourse/vendor/bundle/ruby/3.4.0/gems/mini_sql-1.6.0/lib/mini_sql/active_record_postgres/connection.rb:38:in 'block in MiniSql::ActiveRecordPostgres::Connection#run'
/var/www/discourse/vendor/bundle/ruby/3.4.0/gems/mini_sql-1.6.0/lib/mini_sql/active_record_postgres/connection.rb:34:in 'block in MiniSql::ActiveRecordPostgres::Connection#with_lock'
/var/www/discourse/vendor/bundle/ruby/3.4.0/gems/activesupport-8.0.5.1/lib/active_support/concurrency/null_lock.rb:9:in 'ActiveSupport::Concurrency::NullLock#synchronize'
/var/www/discourse/vendor/bundle/ruby/3.4.0/gems/mini_sql-1.6.0/lib/mini_sql/active_record_postgres/connection.rb:34:in 'MiniSql::ActiveRecordPostgres::Connection#with_lock'
/var/www/discourse/vendor/bundle/ruby/3.4.0/gems/mini_sql-1.6.0/lib/mini_sql/active_record_postgres/connection.rb:38:in 'MiniSql::ActiveRecordPostgres::Connection#run'
/var/www/discourse/lib/mini_sql_multisite_connection.rb:109:in 'MiniSqlMultisiteConnection#run'
/var/www/discourse/vendor/bundle/ruby/3.4.0/gems/mini_sql-1.6.0/lib/mini_sql/postgres/connection.rb:196:in 'MiniSql::Postgres::Connection#exec'
/var/www/discourse/lib/migration/column_dropper.rb:20:in 'Migration::ColumnDropper.mark_readonly'
/var/www/discourse/plugins/voice/db/migrate/20260824214603_mark_chat_thread_title_template_readonly.rb:5:in 'MarkChatThreadTitleTemplateReadonly#up'
/var/www/discourse/vendor/bundle/ruby/3.4.0/gems/activerecord-8.0.5.1/lib/active_record/migration.rb:993:in 'Kernel#public_send'
/var/www/discourse/vendor/bundle/ruby/3.4.0/gems/activerecord-8.0.5.1/lib/active_record/migration.rb:993:in 'ActiveRecord::Migration#exec_migration'
/var/www/discourse/lib/freedom_patches/schema_migration_details.rb:8:in 'block in FreedomPatches::SchemaMigrationDetails#exec_migration'
/var/www/discourse/vendor/bundle/ruby/3.4.0/gems/benchmark-0.5.0/lib/benchmark.rb:305:in 'Benchmark.measure'
/var/www/discourse/lib/freedom_patches/schema_migration_details.rb:8:in 'FreedomPatches::SchemaMigrationDetails#exec_migration'
/var/www/discourse/vendor/bundle/ruby/3.4.0/gems/activerecord-8.0.5.1/lib/active_record/migration.rb:974:in 'block (2 levels) in ActiveRecord::Migration#migrate'
/var/www/discourse/vendor/bundle/ruby/3.4.0/gems/activesupport-8.0.5.1/lib/active_support/benchmark.rb:17:in 'ActiveSupport::Benchmark.realtime'
/var/www/discourse/vendor/bundle/ruby/3.4.0/gems/activerecord-8.0.5.1/lib/active_record/migration.rb:973:in 'block in ActiveRecord::Migration#migrate'
/var/www/discourse/vendor/bundle/ruby/3.4.0/gems/activerecord-8.0.5.1/lib/active_record/connection_adapters/abstract/connection_pool.rb:416:in 'ActiveRecord::ConnectionAdapters::ConnectionPool#with_connection'
/var/www/discourse/vendor/bundle/ruby/3.4.0/gems/activerecord-8.0.5.1/lib/active_record/migration.rb:972:in 'ActiveRecord::Migration#migrate'
/var/www/discourse/vendor/bundle/ruby/3.4.0/gems/activerecord-8.0.5.1/lib/active_record/migration.rb:1186:in 'ActiveRecord::MigrationProxy#migrate'
/var/www/discourse/vendor/bundle/ruby/3.4.0/gems/activerecord-8.0.5.1/lib/active_record/migration.rb:1535:in 'block in ActiveRecord::Migrator#execute_migration_in_transaction'
/var/www/discourse/vendor/bundle/ruby/3.4.0/gems/activerecord-8.0.5.1/lib/active_record/connection_adapters/abstract/transaction.rb:626:in 'block in ActiveRecord::ConnectionAdapters::TransactionManager#within_new_transaction'
/var/www/discourse/vendor/bundle/ruby/3.4.0/gems/activerecord-8.0.5.1/lib/active_record/connection_adapters/abstract/transaction.rb:623:in 'ActiveRecord::ConnectionAdapters::TransactionManager#within_new_transaction'
/var/www/discourse/vendor/bundle/ruby/3.4.0/gems/activerecord-8.0.5.1/lib/active_record/connection_adapters/abstract/database_statements.rb:367:in 'ActiveRecord::ConnectionAdapters::DatabaseStatements#within_new_transaction'
/var/www/discourse/vendor/bundle/ruby/3.4.0/gems/activerecord-8.0.5.1/lib/active_record/connection_adapters/abstract/database_statements.rb:359:in 'ActiveRecord::ConnectionAdapters::DatabaseStatements#transaction'
/var/www/discourse/vendor/bundle/ruby/3.4.0/gems/activerecord-8.0.5.1/lib/active_record/migration.rb:1586:in 'ActiveRecord::Migrator#ddl_transaction'
/var/www/discourse/vendor/bundle/ruby/3.4.0/gems/activerecord-8.0.5.1/lib/active_record/migration.rb:1534:in 'ActiveRecord::Migrator#execute_migration_in_transaction'
/var/www/discourse/vendor/bundle/ruby/3.4.0/gems/activerecord-8.0.5.1/lib/active_record/migration.rb:1508:in 'Array#each'
/var/www/discourse/vendor/bundle/ruby/3.4.0/gems/activerecord-8.0.5.1/lib/active_record/migration.rb:1508:in 'ActiveRecord::Migrator#migrate_without_lock'
/var/www/discourse/vendor/bundle/ruby/3.4.0/gems/activerecord-8.0.5.1/lib/active_record/migration.rb:1453:in 'block in ActiveRecord::Migrator#migrate'
/var/www/discourse/vendor/bundle/ruby/3.4.0/gems/activerecord-8.0.5.1/lib/active_record/migration.rb:1606:in 'ActiveRecord::Migrator#with_advisory_lock'
/var/www/discourse/vendor/bundle/ruby/3.4.0/gems/activerecord-8.0.5.1/lib/active_record/migration.rb:1453:in 'ActiveRecord::Migrator#migrate'
/var/www/discourse/vendor/bundle/ruby/3.4.0/gems/activerecord-8.0.5.1/lib/active_record/migration.rb:1260:in 'ActiveRecord::MigrationContext#up'
/var/www/discourse/vendor/bundle/ruby/3.4.0/gems/activerecord-8.0.5.1/lib/active_record/migration.rb:1235:in 'ActiveRecord::MigrationContext#migrate'
/var/www/discourse/vendor/bundle/ruby/3.4.0/gems/activerecord-8.0.5.1/lib/active_record/tasks/database_tasks.rb:270:in 'ActiveRecord::Tasks::DatabaseTasks#migrate'
/var/www/discourse/lib/tasks/db.rake:135:in 'Object#execute_db_migration'
/var/www/discourse/lib/tasks/db.rake:263:in 'block (2 levels) in '
/var/www/discourse/lib/distributed_mutex.rb:53:in 'block in DistributedMutex#synchronize'
/var/www/discourse/lib/distributed_mutex.rb:49:in 'Thread::Mutex#synchronize'
/var/www/discourse/lib/distributed_mutex.rb:49:in 'DistributedMutex#synchronize'
/var/www/discourse/lib/distributed_mutex.rb:34:in 'DistributedMutex.synchronize'
/var/www/discourse/lib/tasks/db.rake:240:in 'block in '
/var/www/discourse/vendor/bundle/ruby/3.4.0/gems/rake-13.4.2/exe/rake:27:in '<top (required)>'
/usr/local/bin/bundle:25:in 'Kernel#load'
/usr/local/bin/bundle:25:in ''
Caused by:
PG::UndefinedTable: ERROR:  relation "voice_rooms" does not exist (PG::UndefinedTable)
Tasks: TOP => db:migrate
Lo mismo que en este:
Solo ten paciencia.
Hola. Gracias por responder.
No, esos errores ocurrieron mientras se ejecutaba la reconstrucción. Pero tuve algunos errores de red (reset de conexión por el otro lado, etc.) mientras descargaba archivos de GitHub y npmjs. Probablemente eso fue el problema (no se pudo descargar el archivo de migración anterior), pero no puedo afirmarlo con certeza.
