Dealing with some 'small' HTML abuse
The discussion revolves around preventing users, particularly young ones, from abusing the <small> HTML tag by nesting it excessively to make text unreadable. Heather_Dudley seeks a backend solution to stop this behavior without relying on moderation, as the users are not intentionally trying to evade rules but are expressing feelings of being small or unimportant. Canapin suggests using CSS to override the nested <small> tag styles, providing two code snippets to either reset the font size or limit nesting. Falco proposes moderation as an alternative, but Heather_Dudley prefers a frictionless fix. Canapin explains how to implement the CSS solution via a custom theme component in the admin settings. Heather_Dudley confirms the solution works perfectly, allowing her to read posts while still accommodating the users’ intent.
So here’s an interesting problem.
Some of our users (young ones, particularly) have taken to nesting <small> tags to render text effectively unreadable. Aside from just reprimanding them (which feels like overkill because it’s obnoxious, but not against the rules) are there any suggestions for how to prevent this on the back end?
You can see how easy this is to do (and abuse) in the following line:
Example of the small text is here. I can say whatever I want and it requires extra steps for you to read!
Dealing with this requires moderators to actively edit the post to read it or copy and paste.
Override the tag style via CSS?
.cooked {
    small {
        &, small {
            font-size: 1em;
Or if you want the tag small still working but prevent the nesting thing,
.cooked {
    small {
        font-size: .7579em;
        small {
            font-size: 1em;
0.7579em being the default value.
Shouldn’t the moderators deal with abusers? Suspend the user for increasing periods for each flagged post containing abuse.
We can go the moderation route, but to be honest, these are kids (13 and 14, mostly) and I would prefer the more frictionless option of just preventing it and letting them know why I prevented it. They aren’t deliberately trying to avoid moderation, they’re just trying to emphasize their feelings when they communicate, if that makes sense. They are feeling small and unimportant, and are demonstrating this through literal text sizing.
Is this CSS set by theme, or elsewhere? I haven’t done much CSS styling, so I’m not entirely positive where to put this. (This is ideal, btw.)
If you don’t have custom styles yet, I think the best way is creating a new theme component.
Admin → customize → components → create new component
Add the component to your themes.
Still in your custom theme settings, go in edit HTML/CSS, then CSS tab.
Paste the chosen CSS code, save, and voilà. :+1:t6:
Beautiful. Solution implemented, they get their smaller text, and I can READ their posts. Perfect. Thank you!
