Default tags for users
The discussion, titled “Default tags for users,” addresses how to restrict and manage tag selection for users based on trust levels. per_coh asks how level 1 users can choose from a limited set of tags when creating topics, given trust-level restrictions. merefield suggests using Tag Groups to control which tags users can apply based on user groups. pfaffman adds that category settings allow enforcing a minimum number of tags and restricting tags by tag groups. JammyDodger confirms that level 1 users can use unrestricted pre-existing tags and points to the official guide on tag structures. per_coh thanks the community for the assistance.
Newbie question; sorry.
  • How do I let people choose from a limited set of tags when they post? In other words, if min trust to create tag is level 2 and min trust level to tag topics is level 1, how do level 1 users choose a tag for their new topic?
  • Also, is it possible to force users to choose a tag?
Not that I’m aware of
You might be able to achieve what you want with Tag Groups. Go to Tags and Manage Tag Groups. You can set who can use what Tags by User Group by Tag Group. You will need to add the relevant tags to the relevant Tag Group
You can require a certain number of tags per category and you can use tag groups to say what tags apply to a given category.
But maybe if you describe your use case another solution will emerge.
Hello and welcome @per_coh :slight_smile:
In that scenario, TL1 users would be able to use any pre-existing tag that didn’t have a restriction on it. :+1:
For the second point, as @pfaffman said, there are some Tag options in the category settings where you can add some restrictions to what tags can be used for topics in that category, as well as enforcing that new topics have at least x amount of tags from one or more tag groups:
You can read more about tags in Set up structured tagging with tag groups and category tag restrictions
Thanks everyone, for helping out a Discourse newbie.
