Delete tag warning count incorrect
The warning received when deleting tags appears to be capped at 30, even when the actual tag count is higher. Warning count is correct when the tag has 30 or less uses.
6 curtidas
We should fix this, @neil
3 curtidas
I fixed this one today. It now supports numbers higher than 30! Amazing, I know.
7 curtidas
I am nominating this for a Turing Award @neil
7 curtidas
