Como desabilitar a aceitação de uma resposta dada pelo criador do tópico?
Atualmente, o criador da pergunta pode responder à própria pergunta. Assim, se eu conceder distintivos para respostas, os usuários podem obtê-los fazendo e respondendo às próprias perguntas.
Do you create new badges about this?
You must exclude the author id for solved badge.
The default helpdesk badge already exclude this situation. Check the sql from that badge to understand what I mean.
The forum I’m most active on has created a badge, “Learned One”, awarded after a user receives 10 “Solution” checkmarks. I understand that the first checkmark that grants the “Helpdesk” badge can’t be self-bestowed. I don’t think our “Learned One” should be earned using any self-awarded solutions. Is there a way to prevent this?
Bear in mind I’m a user. No administrative access, no documentation save what I’ve gleaned on my occasional forays into this forum.
