Disclaimer section on the "about" page
Would something like an
{{plugin-outlet "about-stats-bottom"}}
*Note - I’m unclear about naming conventions
work for you?
AFAIK @sam is willing to add these
yeah an outlet there is fine.
Hi Sam,
is it possible to include this outlet? I couldn’t find it there.
Thanks!
Could anyone help me to sneak in additional text / html on the about-page? As mentioned above the current page is not compliant with German law and there are currently a lot of rogue lawyers who make loads money with cease-and-desist warnings. Any hack welcome! Thanks so much.
If someone else has this topic: I used CSS to sneak an imprint in.
 .contents .about p:before {
        content: "Impressum text blabla";
Ich würde gerne das finden, damit ich dem Hinzufügen kann.
Wird der per Link gesetzt? Der dann zum Beispiel auf eine wp verweist.
Oder wie und wo finde ich das. Sehr tolles Innenleben. Da werden noch etliche fragen kommen .
Da ich die benötige. Vielleicht kannst du mit mir dich darüber mal austauschen
Wo finde ich das bitte? Da ich das benötige und wüsste zu gerne, ob das über einen Link gemacht wird, der auf eine wp oder sonstiges verweist
Hey @carrabelloy,
I’m not really sure what you are asking about, and old topics may contain outdated information.
If the purpose is to add a disclaimer page directly available from the home page of your forum, there are several ways to do that.
If you want to edit the pages FAQ, Terms of Service and Privacy, their associated topic is located in the Staff category.
If it doesn’t answer your questions, can you be more specific on what you are trying to achieve? :slight_smile:
her @Canapin Yes, I need that, because I touch a hot iron and that must be legally compliant.
Also that with the logging that it is users from 18, is quite important to me.
Now I was wondering if I can use this from my Mastodon as a link.
I thank you or you for all the information. May I contact you or you more often? My English is really brittle. Please excuse that. But maybe we can still exchange information. I would be glad.
Hallo @carrabelloy!
Die Nutzungsbedingungen, Datenschutzerklärung und FAQ deines Forums kannst in der “Team” Kategorie finden und bearbeiten. Falls du lieber auf dein Blog verlinken möchtest, dann kannst du in den Einstellungen → Rechtliches die URLs anpassen.
Dein Forum scheint eine Registrierung zu benötigen. Falls du schon auf der Anmeldeseite einen Text oder Links zu Nutzungsbedingungen anzeigen möchtest, dann könntest du die Trendy Login Komponente ausprobieren.
Nein, ich weiß nicht, ob ich eine Deutsche Fassung dazu genauso bekomme. Die sollten mal eine Spenden-Uhr aufhängen, doch darauf komme ich noch mal später, ich mag Open-Source. Und ich danke Ihnen genauso für das Feedback dazu @gerhard
Deutsche Versionen der Nutzungsbedingungen, Datenschutzerklärung und FAQ sind verfügbar. Diese sind aber nur reine Übersetzungen aus dem Englischen und rechtlich nicht geprüft.
Falls du mit einem Forum in englischer Sprache begonnen hast, sind diese Dokumente auch auf Englisch erstellt worden. Du kannst sie jedoch im Admin-Panel unter Anpassen → Text mit den deutschen Übersetzungen überschreiben, indem du dort auf “Text ersetzen…” klickst.
Ich habe sie mir komplett übersetzen lassen und werde hier den Rest zu führen
https://darknight-coffee.org/blog/?tag=datenschutz
Danke für den Hinweis noch mal @gerhard
Wo findet man die Texte denn?
They appear as topics in the staff (Team) category, when you add the company name in the site settings.
I still need an imprint, is it possible to create a post in Staff manually and make it available to everyone?
You can always create a topic in a public category and link to that from various places like the first sidebar section. But then it would look like a topic in the forum and not a standalone page. That might be acceptable to you.
There is currently no way to create such a topic and add it to the navigation menu so it appears as a page alongside the about page, terms of service and privacy notice. I think this would be an interesting feature request. Then you could have this:
Screenshot 2024-09-20 at 7.31.00 AM
One solution that comes to mind is to switch to the experimental about page, which soon will become the only about page, and then to edit site texts to edit the “Contact us” section on the right side so it includes full impressum details. To do that, look for “site texts” on the sidebar, switch to your site’s language, then search for “if you come across”. You can also rename the “Contact us” header to “Impressum” by searching for that.
If you need more space, you could also add impressum details to the site description, which appears directly on the login page on private sites and on the about page.
