The discussion revolves around an issue with Discobot, a bot on the Discourse platform, interacting with a non-technical user. Martin_Cash shared screenshots of the interaction, where the bot asks the user to post a link, and after the user fails to do so correctly, the bot repeats the request. However, the user gets blocked by the system for spam.
Codinghorror points out that the relevant issue is the bot’s instruction to say “skip” to bypass the step. Tgxworld agrees that users can run afoul of the spam URL link checking and plans to disable the check during the bot interaction.
Tophee suggests improving the bot’s copy to avoid the issue, either by removing bullet points or changing the bot’s reply to provide clearer instructions. Codinghorror mentions that PMs should be excluded from the spam link check due to false positives and instructs Tgxworld not to follow up on the issue.
Codinghorror also changes the bot’s instruction to make the link easier to cut and paste. Finally, Neil commits a fix to ignore PMs from the spam link check.
It looks like during a “start new user” introduction, Discobot asks the user to post a link, after the user failed to provide what Discobot was looking for, Discobot repeated the request so the member could try again. The member tried to post the link a second time (incorrectly) and got blocked by System for spam.
Looking at these screenshot two things come to mind:
As a user, I would be quite annoyed with the bot telling me that it can’t see a link in my post when there clearly is a link there. So I think the copy could be improved here. I’m not sure what the best way is but I see two options:
(i) remove the bullet points in the bot’s message so that this pasting error doesn’t occur in the first place.
(ii) change the bot’s reply to something like “Sorry, if there is a link in your reply, there is something wrong with it. Are you sure it is on a line on its own, with nothing before or after it? Can you try adding…”
I told @neil we need to exclude all PMs from the spam link check since there have been wayyyyy too many false positives on that in a variety of scenarios, not just this one – so you don’t need to follow up on this @tgxworld.
using the < and > chars around the link to make it remain a plain not-oneboxed link, but easier to cut and paste.
(it’s not even possible to select that bullet in Chrome or Firefox, try it yourself, so this also presupposes a very bizarre browser the user is using..)
