DiscoTOC optie ontbreekt in het tandwielmenu
DiscoTOC Option Missing from Gear Icon Menu
User agemo reported that the DiscoTOC option was missing from the post cog menu after updating to version 2.9.0.beta10 [99d9c933c6]. Despite doing a rebuild, the issue persisted. JammyDodger suggested checking if the feature was enabled for the theme and if it was being used in the first post of a topic, but agemo confirmed that both conditions were met.
Further troubleshooting suggested checking the minimum trust level to create TOC setting, but agemo confirmed that this was not the issue. Deleting and reinstalling the component did not resolve the issue initially, but agemo eventually discovered that the solution was to re-add the component to the theme after reinstalling.
Updated yesterday, and now today we see the DiscoTOC icon missing form the Post Cog.
So can’t build a TOC.
Any ideas beyond doing a rebuild?
Update - Did a rebuild some hours later that evening.
This made no difference, still no sign of the option in the post cog.
I’ve just had a quick run-through on my test site and it appears to be working okay on there:
Forgive me for the basics, but just to check :slight_smile:, have you enabled it for the theme? And are you using it in the first post of a topic?
Yes and yes.
My original test post with DiscoTOC is still there and works.
So I have had it work in the past.
There’s a setting for minimum trust level to create TOC which might be worth a check? Other than that I am unsure. If it’s not that we can split this off into a Support topic to get more eyes on it. :+1:
Do you have any other theme components/customisations/anything else unusual that may be affecting it in some way?
As Admin I’m always above the level and it wasn’t changed since installation of the component.
I’ve deleted a few recent components to pair back to what it was like when DiscoTOC was installed, if that doesn’t work, I can only suggest something broke in an update.
I thought that might have been a long shot. :slight_smile: I’m not sure why it’s missing from your setup. It’s working on my test site, as well as here on Meta and Try.
Could you try deleting and reinstalling it and see if that helps?
Or perhaps it’s device-related - could you try it on something else?
Right, I deleted the component. Then reinstalled the component.
  • Still no option in post cog
  • previous DiscoTOC test post does not utilise the feature.
This worked after I realised I had forgotten to re-add to theme!
The old turn it off, turn on solution… why didn’t I think of that! :laughing:
