Evidenziazione del testo CommonMark in Discourse?
Probably not really a bug but, I know that “standard” Markdown discussions are somewhat fraught and this question seems to not be dealt with in the latest ComonMark spec but…
It appears that, in accordance with at least one (the Ghost project) guide of the CommonMark spec:
~~strikethrough~~
should give you a strikethrough (and it does) but
==highlight==
should give you a ==highlight== text - and it doesn’t.
Attempting to use <span style=“background-color:yellow;”> tags or other means seems to also not work for me…
So, based on the CommonMark used by Discourse, is there a way to do text highlighting? Is there a better guide for us to use to get answers to questions like this?
3 Mi Piace
La versione di Markdown di Ghost è pienamente conforme a CommonMark con alcune altre funzionalità utili come le note a piè di pagina.
Il tag <mark>Evidenzia</mark> rientra tra le “altre poche” funzionalità.
<mark>Evidenzia</mark> rientra tra le "altre poche" funzionalità.
Puoi provare a integrare GitHub - markdown-it/markdown-it-mark: <mark> tag plugin for markdown-it markdown parser · GitHub come plugin utilizzando Developer's guide to Markdown extensions.
9 Mi Piace
Interesting (but, beyond what I can do in the 2 weeks I have to put into this at this time)…
Playing on the Markdown-it demo page, exactly what I want is available. Off hand, do you know if:
  1. The version of Markdown-it included in Discourse is feature hobbled in some way?
  2. Markdown-it might be an older version in the Discourse release?
(I know that this is easily found out by me but you were so quick in responding before that I’m now a spoiled user dependent on you :grin:)
We use just markdown-it.
That demo also supports footnotes which are a markdown-it plugin, that we provide at Discourse Footnote.
3 Mi Piace
Good catch and clue…
On our test site, installed Discourse footnote plugin and footnotes work fine (settings are all turned on) but highlighting is still as before…
Thanks again for your suggestion…
Someone would have to re-package the highlight markdown-it plugin into a Discourse plugin for it to become available. You could likely take a stab at it by forking the footnote plugin and finding all instance of footnote and replacing it with “mark”
8 Mi Piace
This caught my interest as I thought it would useful on my installation as well. So here is a plugin for highlighting. Being as it is my first plugin, I suspect it needs a fair bit of cleanup even with having used other plugins as templates/inspiration. It did work in my test environment though.
https://github.com/sirideain/discourse-mark
10 Mi Piace
Ti ho aggiunto al gruppo @plugin_authors, quindi sentiti libero di pubblicare un post completo su Customization > Plugin al riguardo!
3 Mi Piace
We already have insert and delete
We already have <ins>insert</ins> and <del>delete</del>
8 Mi Piace
Vorrei proprio usare questo @sirideain
Sto ricevendo questo messaggio?
"“Errore di importazione: about.json non esiste o non è valido. Sei sicuro che si tratti di un tema Discourse”?
Grazie.
Questo è un plugin, non un tema. Dovrai consultare Install plugins on a self-hosted site
3 Mi Piace
