Dear Discourse community,
I would like to install Discourse software on my dedicated server that uses CentOS 6.7, but I have received the following reply from my support team:
** In order to install discourse, it will require to install docker demon but it requires a 64-bit installation regardless of CentOS version. Also, kernel must be 3.10 at minimum and current kernel version is “2.6.32-573.7.1.el6.x86_64”. CentOS 7 runs the 3.10 kernel but installed CentOS 6.7 does not. **
So I have asked my support to upgrade kernel to 3.10 since I can’t upgrade the server to CentOS 7.
Also, can docker daemon 64-bit be installed on CentOS 6.7 version?
Thanks in advance,
Nik
