Instalação do Discourse sem SWAP
Hello,
are there any way to install Discourse without SWAP, because my VPS uses OpenVZ.
I will not have too much posts and users, so 2gb of memory maybe enought?
You can edit app.yml by hand or comment out the part that checks for memory. Discourse will probably run, but will run out of memory when you try to upgrade, or perhaps, do the initial bootstrap.
If you do that and it doesn’t work, don’t be surprised.
1 curtida
We don’t support installs in OpenVZ, you need a KVM compatible VPS.
8 curtidas
Thank you for the answers, then I failed with OpenVZ
You can close the topic!
