OpenVZ swap space error during install
The user is trying to install Discourse on an OpenVZ-based VPS with 2.5GB of RAM but encounters issues with swap space and Docker. The installer warns that 2GB of swap is required, but creating a swap file fails due to OpenVZ’s limitations, which prevent adding swap or modifying system settings like vm.swappiness. The user is advised that OpenVZ is a container-based system, not a full VM, and thus incompatible with Docker and certain configurations. After modifying discourse-setup to bypass memory checks, the user still faces a Docker daemon error, as Docker cannot run on OpenVZ. The community recommends switching to a provider offering full VMs, such as DigitalOcean, and warns against using chmod 777, which is unsafe. hosyminh seeks help, while supermathie provides technical guidance and solutions.
./discourse-setup
WARNING: Discourse requires at least 2GB of swap when running with 2GB of RAM
or less. This system does not appear to have sufficient swap space.
Without sufficient swap space, your site may not work properly, and future
upgrades of Discourse may not complete successfully.
Ctrl+C to exit or wait 5 seconds to have a 2GB swapfile created.
2097152+0 records in
2097152+0 records out
2147483648 bytes (2.1 GB, 2.0 GiB) copied, 7.2644 s, 296 MB/s
Setting up swapspace version 1, size = 2 GiB (2147479552 bytes)
no label, UUID=6e02cc8b-b5af-412b-9121-3fc09f0055a0
swapon: /swapfile: swapon failed: Operation not permitted
/swapfile       swap    swap    auto      0       0
sysctl: permission denied on key 'vm.swappiness'
vm.swappiness = 10
Failed to create swap, sorry!
help me !!
root@CTR386846:/var/discourse# lsb_release -a
No LSB modules are available.
Distributor ID: Ubuntu
Description: Ubuntu 16.04.3 LTS
Release: 16.04
Codename: xenial
what is the Ram capacity ?
and host
you will have to create inough swap space
CPU: Intel XEON E5645/X5650
  • Core: CPU 2 Core
  • Cloud storage: 25GB
  • RAM: 2.5GB
What flavour of VPS is this? My guess is that you’re using a provider that gives you a container instead of a VM.
Can you please run: apt-get install virt-what and send the output of virt-what?
root@CTR386846:/var/discourse# sudo virt-what
openvz
Confirmed: openvz is a container-based virtualization system, not a full server. You won’t be able to add swap or change sysctls.
Using docker may also not work. If not, I suggest a container from a provider such as Digitalocean.
Thank ! if i don’t create swap
=> help me setup discourse ?
Can you run: free -g --si and show the output? free -m --si as well?
We may not be handling systems with 2.5GB correctly. If you do have 2.5GB, you can cheat by making the following change on line 108 of discourse-setup and rerunning the installer:
--- old/discourse-setup
+++ new/discourse-setup
@@ -108,7 +108,7 @@ check_disk_and_memory() {
   if [ "$os_type" == "Darwin" ]; then
     avail_mem=$(check_osx_memory)
   else
-    avail_mem=$(check_linux_memory)
+    avail_mem=3
   fi
   if [ "$avail_mem" -lt 1 ]; then
i change discourse-setup and update
root@CTR386846:~# cd /var/discourse
root@CTR386846:/var/discourse# ./discourse-setup
-bash: ./discourse-setup: Permission denied
chmod -R 777 /var/discourse
is ok => thanh so much
Configuration file at containers/app.yml updated successfully!
Updates successful. Rebuilding in 5 seconds.
Device “docker0” does not exist.
Cannot connect to the docker daemon - verify it is running and you have access
real 0m0.063s
user 0m0.037s
sys 0m0.018s
help me ??
real 0m0.038s
user 0m0.012s
sys 0m0.013s
root@CTR386846:/var/discourse# service docker restart
Job for docker.service failed because the control process exited with error code. See “systemctl status docker.service” and “journalctl -xe” for details.
This is a terrible idea. Next server, chmod the script to 755.
Your VPS does not support docker. I suggest a full VM from a different provider.
