Discourse está enviando correos electrónicos aunque el envío de correos esté desactivado
Hi!
Since we updated to 2.2.2 (i think it was) on the first of march Discourse began sending out emails even though we have emailing disabled.
Actually we had it set to “non-staff”, but even setting it to “yes” doesn’t help.
Any ideas why this is happening? :slight_smile:
2 Me gusta
Is your sidekiq queue backed up and sending stuff that was queued before you disabled mail?
I’ll confirm this one. I just had a beta site send emails to the entire user base even though the setting is at non-staff. Emails went out to 1,000 people who shouldn’t know the site exists yet.
Edit: Following up here. I decided to break the email configuration on this beta site to get emails to stop. I could trigger emails to non-staff users pretty easy with mentions and such even though the disable emails setting was at non-staff.
2 Me gusta
I don’t pretend to understand how things work at this level (maybe there are tests elsewhere that I don’t know about), but I don’t see how this code would skip sending if disable_emails was staff_only. Also, if I remember correctly, the old value used to be true/false, so it looks like if it had been set to true it would fail matching the yes in the test below (or maybe that would have been fixed in a migration somehow or Rails magically thinks that true and yes are the same?).
3 Me gusta
Thanks for the report. I think this is an unintended side effect of a change in December. I’ll get it fixed now.
8 Me gusta
I have reverted that commit, and opened a PR to make some further improvements to the “disable email” logic:
https://github.com/discourse/discourse/pull/7238
7 Me gusta
Thank you to @david for fixing this in
https://github.com/discourse/discourse/commit/a9d5ffbe3d9b40db92a745dd588f2eaedc849c5f
7 Me gusta
This topic was automatically closed after 3 days. New replies are no longer allowed.
