Don
1
Hello
This is a small hack (redesign) to the official offline indicator.
Site Setting: enable offline indicator
I’ve override the offline indicator template to add icons to it. To add the icon, I put the following two icons (wifi and slash) each other.
Default
Modified
Here is the repo (you can use it or use as template if you have other ideas): GitHub - VaperinaDEV/discourse-offline-indicator-hack
Lilly
Nice! I love how you combined icons - cool trick!
Don
4
Hello
I’ve updated the theme component because now the offline indicator component is a .gjs so we can’t override it’s template.
I use the Discourse Easy ‘SVG Icon’ and ‘Emoji’ in CSS helper. I’ve added the Google Material Wifi Off icon. So this way we don’t need to merge two separate icons.
