Retours Discourse
Setting up a certain trust level or group membership as requirement would be great. I would love to implement it as premium feature for premium members in my forum.
1 « J'aime »
I really want to include this in our forum that’s being imported from phpbb… I’m just not sure on how the users will understood that they will have a “reactions” and a “like” altogether… I fear that they will end ignoring the like in favor of the reactions :confused:
I suppose, you could tweak the UI with CSS and/or Jquery so that people see multiple emojis to react with
What would be even more amazing is to grey out the extra emojis and lead the CTA to buy a certain group membership to enable that feature.
Retort includes the retort limited emoji set setting to present a fixed list of emoji.
You could pair that down to 3/4 reactions beyond ‘like’ to encourage users to use the like button when it’s relevant.
That doesn’t sound amazing, that sounds really really user-hostile.
Seems like disabling the plugin and rebuilding still breaks the post content. I had to go to finder -> ~/discourse/plugins, then had to manually remove the retort folder.
@gdpelican The retort plugin is inteferring with the emoji selection box, see this post:
https://meta.discourse.org/t/emoji-button-not-showing-emojis-when-browser-full-screen/119468/10
Je peux confirmer le bogue ci-dessus
Bonjour @Vaping_Community, @Jose_C_Gomez :smiling_face:
Cette PR résout-elle votre problème ? FIX: Prevent emoji-picker from not showing by SantosGuillamot · Pull Request #7856 · discourse/discourse · GitHub
Nous rencontrions des difficultés similaires, qui sont désormais résolues grâce à cela. (Peut-être devrez-vous reconstruire votre application).
Oui, c’est maintenant corrigé.
Je propose à mes utilisateurs une application iOS/Android leur permettant d’accéder à mon forum.
Lors de l’ouverture des sujets dans les applications, les messages ne se chargent souvent pas correctement, ou seule la navigation apparaît.
Je vois également ces erreurs dans /logs :
TypeError: Cannot read property 'get' of undefined
    at i.disabledFor (https://.../assets/plugins/retort-0e38325ecc1e77022640749d263c616fa2014661562526df5557240511da536a.js:1:3734)
    at https://.../assets/plugins/retort-0e38325ecc1e77022640749d263c616fa2014661562526df5557240511da536a.js:1:4642
    at https://.../assets/application-005c06796edb69789ba3362843ad68e4f0e5b629e4bce0ccfce36db53770401e.js:75:13612
    at Array.map (<anonymous>)
et
TypeError: undefined is not an object (evaluating 'e.get')
disabledFor@https://.../assets/plugins/retort-
0e38325ecc1e77022640749d263c616fa2014661562526df5557240511da536a.js:1:3733
0e38325ecc1e77022640749d263c616fa2014661562526df5557240511da536a.js:1:4653
map@[native code]
Désactiver Retort résout le problème. Dans un navigateur mobile standard, tout fonctionne correctement.
Ce bug signifie que je devrai soit arrêter d’avoir une application, soit désactiver Retort, ce qui ne sont pas des alternatives idéales :smiley: Je serais heureux de payer pour que cela soit corrigé – si cela peut aider :slight_smile:
1 « J'aime »
@DiscourseMetrics J’ai poussé une correction qui, je crois, résoudra ce problème, même si je dois admettre ne pas avoir lancé une application séparée pour vérifier. Pourriez-vous récupérer la branche account-for-missing-post et vérifier que le problème est résolu ?
git clone -b account-for-missing-post https://github.com/gdpelican/retort.git
2 « J'aime »
Les sujets vides se produisent moins maintenant, nous sommes donc sur la bonne voie :slight_smile:
Maintenant, nous constatons ces erreurs :
TypeError: Impossible de lire la propriété 'find' de undefined
    at i.postFor (https://.../assets/plugins/retort-e5332d5fc1fdd242b0b5702995f9e863e10f7e9def1d713e49cce1c391de94ed.js:1:3337)
et
TypeError: i est undefined
Url: https://.../assets/plugins/retort-e5332d5fc1fdd242b0b5702995f9e863e10f7e9def1d713e49cce1c391de94ed.js
et
TypeError: undefined n'est pas un objet (évaluation de 'i.retorts')
1 « J'aime »
D’accord, donnez-moi un peu de temps et je ferai un examen plus approfondi de cela ; il semble que l’application fasse quelque chose de différent du site web.
Si vous pouvez me donner accès à l’application ou au forum en question, cela m’aiderait beaucoup. :slight_smile:
1 « J'aime »
L’utilisation de
.post-retort{
//mon code CSS divers ici
ne modifie pas les paramètres par défaut. Des idées ? Merci
1 « J'aime »
J’organise un événement d’Halloween pour ma communauté @gdpelican et j’utiliserai :candy: comme réaction de réponse.
Cependant, pour être honnête, je ne connais rien au SQL. Je souhaite créer deux requêtes pour l’explorateur de données. L’une affichera qui a reçu le plus de réactions :candy:, et l’autre qui en a donné le plus. Est-ce réalisable ? Merci de votre temps !
Confirmé ici. Nous avions auparavant personnalisé ce CSS. Maintenant, l’héritage est différent d’une manière ou d’une autre, et les valeurs par défaut écrasent tout CSS que nous définissons. Nous apprécierions une correction ou, à défaut, une solution de contournement.
Dans notre cas, la couleur de fond est particulièrement problématique car la valeur par défaut utilise une couleur de notre thème qui est trop sombre et masque les icônes.
J’ai une réplique qui a été ajoutée à un post 22 fois.
Si j’essaie de la presser en tant que numéro 23, j’obtiens une erreur 403 Serveur interne.
Cette erreur est affichée dans les journaux :
Échec de la gestion de l’exception dans le middleware d’exception de l’application : PG::StringDataRightTruncation: ERREUR : la valeur est trop longue pour le type character varying(255)
Je me demande s’il stocke le nom d’utilisateur de chaque personne ajoutant une réplique et si le champ est trop court lorsque beaucoup sont ajoutées ? :slight_smile:
3 « J'aime »
Je me demande s’il y a une limite au nombre de réactions autorisées par sujet ou par message. :slight_smile:
1 « J'aime »
Je n’aime pas le ‘bumping’, mais le bug d’héritage dans le CSS pour .post-retort rend vraiment les répliques dysfonctionnelles pour nous, car la couleur sombre, dans notre cas, rend de nombreux emojis presque invisibles.
2 « J'aime »
Est-il possible d’afficher la fenêtre contextuelle au-dessus de tous les boutons ? Actuellement, les fenêtres contextuelles sont situées à l’intérieur de chaque élément de bouton, de sorte que la suivante recouvre la précédente.
1 « J'aime »
