clay
(Clay Heaton)
Agosto 13, 2015, 6:08pm
1
After an attempt to upgrade to v1.4.0.beta8 got stuck, I rebuilt the app, per some advice in a thread here. When the app rebuilt, it upgraded itself. However, Now I see this at my admin/upgrade screen:
Sadly, there’s no upgrade going on. Any idea how to fix this?
Same as many other responses here, ssh in and do the 3 line magic
cd /var/discourse
git pull
./launcher app rebuild
clay
(Clay Heaton)
Agosto 13, 2015, 6:27pm
3
Sorry if I wasn’t clear – the screens above are the result of me having done exactly what you suggested. Should I just do it again and hope the problem goes away?
Odd, try clicking the reset upgrade button.
Is the version in view source correct, e.g. Latest?
clay
(Clay Heaton)
Agosto 13, 2015, 10:19pm
5
So, interestingly, it didn’t work until I tried to rebuild the app again. This is what that looked like:
clayh@machine:~$ cd /var/discourse
clayh@machine:/var/discourse$ git pull
remote: Counting objects: 5, done.
remote: Compressing objects: 100% (4/4), done.
remote: Total 5 (delta 0), reused 0 (delta 0), pack-reused 0
Unpacking objects: 100% (5/5), done.
From https://github.com/discourse/discourse_docker
0b73fae..9b102d5 master -> origin/master
Updating 0b73fae..9b102d5
Fast-forward
image/discourse_test/Dockerfile | 2 ++
1 file changed, 2 insertions(+)
clayh@machine:/var/discourse$ ./launcher app rebuild
Config file was not found, ensure containers/rebuild.yml exists
Available configs ( app )
Following that, I hit the Reset Upgrade button and it upgraded as expected and all looks normal. Weird.
./launcher rebuild app
Sorry, I got the terms backwards, I was typing that on iPhone – so you didn’t do a rebuild just then.
sjmscott
(Steve)
Julho 2, 2016, 10:25pm
7
To confirm, it worked for me. I’m all set!
I was drawn in my the “magic” of this post and didn’t read down to the bottom to see the correction.
