Discourse WordPress Media
Hey Guys,
Quick question, currently every time I post a WordPress post to Discourse it works great but the media does not get added, is there anything I can do to remedy this? I’m talking about a normal wordpress post with images added to it not showing images in the related discourse topic.
Thanks!
Kve
Are you publishing the full post to Discourse, or are you just publishing an excerpt? What are you seeing where the images should be?
Hey Simon, thanks for the swift reply. I post excerpt and see white space where the images would be. I’ll see if full post fixes it if so i’ll just enable that.
Edit: Enabling full posts seems to fix the problem which is sufficient for my usecase.
