If I have a few notifications, and if I press Dismiss,  the bottom part of the panel shifts out, like it’s cut out of the panel.
Images:
I use ask.replit.com using Google, on an Android phone.
Images:
Does this reproduce here as well?
Hi @sam , for that, i need a notification to test.
@sam Wait could you try that again?
Thanks!
Hi @sam, it doesn’t seem to happen here. Just Replit Ask.
I see, then it is likely theme related, the notification menu is modified there. (seeing round corners etc…)
Ok, thanks. I’ll report it there then.
