عرض الاسم الكامل لجميع التصنيفات
Hi all,
Let me start by wishing you guys an happy new year 2018 :smiley::smiley:
One of my users asked me if it’s possible to display the categories/sub-categories full name. Currently it seems names are truncated after the 14 characters.
It makes the UEX slightly confusing.
Thx
Seb
There are plans for @j.jaffeux to replace this problem element with our newer select-kit, hopefully that will happen early in 2018, beyond that you can override the css in Admin, customize.
This might not cover everything but it’s a start.
.category-dropdown-menu is set to minimum-width: 131px by default.
You can override that number to increase the width to accommodate for wider category names..
For example, this:
.category-dropdown-menu {
    min-width: 180px; //Increase the number to the desired width.
Will give you this result:
Hi,
Thx for your quick answer. I can increase the menu size but the text still get truncated.
Got it working with the following CSS code
.category-dropdown-menu, .badge-category {
       max-width: none !important;
