The user, new to networking, is setting up a Discourse forum on a DigitalOcean droplet and has linked their DNS to Cloudflare. They ask whether DNS records for Brevo (their transactional email service) must be in Cloudflare for Discourse to install properly. supermathie clarifies that DNS records like MX and TXT (for SPF/DKIM) are needed for email functionality, but they don’t have to be in Cloudflare if the mail domain is separate. pfaffman confirms that if Cloudflare is managing DNS, all records must be there, but if Brevo manages its own DNS for email, that’s acceptable. The user confirms the Discourse and mail domains are different, and supermathie notes that while managing DNS across two services is possible, it’s more complex than keeping everything centralized. The user appreciates the guidance and plans to learn more about DNS.
Not sure which records you mean, but either way, no.
FYI:
MX records tell other entities on the Internet “these are the servers you contact to send mail to this domain”
TXT records are used for many purposes and the ones you’re talking about are likely either SPF or DKIM, both of which inform other entities “this is how you authenticate mail claiming to be from my domain”
So cloudflare is now in charge of your DNS? Not sure what “linked it to their DNS zone” means, but I think you mean that your DNS records are now at cloudflare. You can check at Free Whois Lookup - Whois IP Search & Whois Domain Lookup | Whois.com and if the Name servers are cloudflare, then your DNS is at cloudflare.
If cloudflare is where your DNS records are, you need to have all DNS records there. It is pretty good at copying all of your records if/when you change to having it be your DNS service. If Breve needs any DNS records set, you need to see that they are set wherever your DNS is.
Thanks for your reply. So yes Cloudflare is now in charge of their DNS. Breve is the transactional email service the non-profit uses and all I needed to do to install properly was to feed the installer the SMTP information. So forum is up and running but Breve is still in charge of the rtansactional email’s DNS. You’re telling me it should be Cloudflare? What do I risk by keeping the email’s DNS with Breve?
On a similar note, I couldn’t get the setup to work (because ports 433 and 80 failed) until i deselected the proxy button in CloudFlare. Don’t really know if I should reactivate it now that the forum is up and running.
In the case there’s no risk of having different parties being the nameservers for the domains, it’s just more work to manage rather than having everything in one place.
