Docker לא נמצא/לא עובד
סיכום מבוסס בינה מלאכותית
Docker not found/working
Jereme_Wong is experiencing issues with Docker after an upgrade on their DigitalOcean-hosted server. They’ve tried rebooting, but the issue persists. pfaffman suggested checking a related post on Meta Discourse and running the command as root.
After running the command as root, Jereme_Wong encountered an error message indicating a problem with their Docker installation. They’ve tried reinstalling Docker, but the issue remains.
pfaffman asked about the operating system, and Jereme_Wong confirmed they’re running Ubuntu 14.04.5 LTS. pfaffman suggested upgrading to a clean 18.04 installation and restoring from a backup, as 14.04 is near end-of-life.
Jereme_Wong has accepted pfaffman’s offer to fix the issue for a fee.
Hi,
I can’t seem to get my docker to work after the upgrade.
Can some kind soul point me the right way? I’m a noob at this. Thanks.
I’m hosted on DigitalOcean.
Cheers.
Did you look at Troubleshoot docker installation issues? Are you running as root?
Maybe reboot?
Did a reboot. Since last night, the screen is just hanging at the Ubuntu loading screen.
:sob:
Then it’s not a Discourse problem, and likely not a docker problem.
It is likely a hardware issue. Networking might be my guess, but this isn’t going to be the place to get help.
Did the post in the suggested “See:” help any?
https://meta.discourse.org/t/docker-error-on-bootstrap/13657/18?u=mittineague
Hi guys, I ran it from root.
When I tried to rebuild the app, this is the error presented:
root@forum:/var/discourse# ./launcher rebuild app
/usr/bin/docker: Error response from daemon: OCI runtime create failed: container_linux.go:348: starting container process caused "process_linux.go:297: copying bootstrap data to pipe caused \"write init-p: broken pipe\"": unknown.
Your Docker installation is not working correctly
See: https://meta.discourse.org/t/docker-error-on-bootstrap/13657/18?u=sam
I have tried to remove the docker and then reinstalling it. Same error message as above.
Any help would be appreciated.
What OS are you using?
> root@forum:~# cat /etc/os-release
> NAME="Ubuntu"
> VERSION="14.04.5 LTS, Trusty Tahr"
> ID=ubuntu
> ID_LIKE=debian
> PRETTY_NAME="Ubuntu 14.04.5 LTS"
> VERSION_ID="14.04"
> HOME_URL="http://www.ubuntu.com/"
> root@forum:~# lsb_release -a
> No LSB modules are available.
> Distributor ID:	Ubuntu
> Description:	Ubuntu 14.04.5 LTS
> Release:	14.04
> Codename:	trusty
If you’re in digital ocean, I’d recommend to install a clean 18.04 and start over. Then restore your backup to the new server. 14. 04 if close to end of life anyway.
If you don’t have a backup then you can rsync the discourse directory to the new server and then rebuild. I suspect that digital ocean has a page about rsync.
If it’s an emergency that you want to throw money at, I’ll fix it for $300 Redirecting…
Thanks @pfaffman.
Happy to have you fix it. I’ll reach out separately via email to you.
