root@discourse:~/var/discourse/discourse_docker# ./launcher bootstrap app
time="2015-03-05T16:38:23-05:00" level="fatal" msg="Cannot connect to the Docker daemon. Is 'docker -d' running on this host?"
Cannot connect to the docker daemon - verify it is running and you have access
I followed the Quick Install guide. I keep getting the error above. I think docker has not been installed correctly. How do you reinstall it? When I run docker -d, I get the following
INFO[0000] +job serveapi(unix:///var/run/docker.sock)
INFO[0000] Listening for HTTP on unix (/var/run/docker.sock)
INFO[0000] +job init_networkdriver()
INFO[0000] -job init_networkdriver() = OK (0)
INFO[0000] WARNING: Your kernel does not support cgroup swap limit.
INFO[0000] Loading containers: start.
INFO[0000] Loading containers: done.
INFO[0000] docker daemon: 1.5.0 a8a31ef; execdriver: native-0.2; graphdriver: aufs
INFO[0000] +job acceptconnections()
INFO[0000] -job acceptconnections() = OK (0)
Then it just does nothing. Please help!
