Hi, i trying to follow discourse/docs/INSTALL.md at main · discourse/discourse · GitHub
Debian Wheezy
Docker version 1.5
> ./launcher bootstrap app
> time="2015-03-12T17:45:08+01:00" level="fatal" msg="Error response from daemon: Cannot start container f667a79b0a5fd56be273b0619ea67a6ae0ca7458b334d310ab05ac7d0a673f5f: fork/exec /var/lib/docker/init/dockerinit-1.5.0: invalid argument"
> Your Docker installation is not working correctly
> See: https://meta.discourse.org/t/docker-error-on-bootstrap/13657/18?u=sam
Please i need help ^^.
zogstrip
(Régis HANOL)
12 maart 2015 om 21:09
Debian is too much conservative about the package they use which apparently breaks Docker
Debian is horrible. We don’t recommend it. You can’t even run Docker on it for the same reason.
Thanks for your answer.
I can’t not change the system OS i have already many application install on my server and it will be huge work to reinstall all.
Do someone know a workaround to install docker on debian?
elberet
(Jens Maier)
15 maart 2015 om 20:48
4
No, there is no easy workaround, short of installing a backported kernel with aufs support. If that’s not an option and you’re really stuck with Debian wheezy, you might as well attempt an unsupported docker-less installation.
