Does AI triage automation scan DMs between regular users?
Hi,
I have configured the “Triage posts using AI” automation for content moderation on my platform (madeira.community — a multilingual business directory for Madeira island).
The automation works perfectly for public posts. However, I enabled “Include personal messages” option and found that DMs between regular users are not being scanned at all.
My concern is real: bad actors can use private messages to conduct illegal activities — drug dealing, sharing stolen financial data, grooming — while completely bypassing AI moderation that works fine on public content.
My questions:
  1. Does “Include personal messages” actually support scanning DMs between two regular users (non-staff)?
  2. If not — is this by design or a known limitation?
  3. Is there any supported way to apply AI triage to private messages between regular users?
I found a reference to a commit “Skip PM scanning in LLM triage by default” which suggests this may be intentional. But the UI option exists — so I am confused about what it actually does.
Thank you
Yes it does, if you enable that option it should be scanning PM’s.
How did you determine this?
“I tested it by sending a private message between two regular users (testUser to darinauser, both non-staff) with clearly illegal content: ‘кокаин. оружие. гранаты’ and ‘порно. грязь. разврат. насилие’. The messages were delivered and not flagged. The Review Queue remained empty. The same content in public posts was flagged immediately.”
I can confirm that they were not processed, the topic ID’s of those PM’s (210, 211, 212 and 214) and post id’s are not in the ai_api_audit_logs table.
I think “Topic Type” “All topics” means all topics that are not private messages.
Could you try to leave that one empty?
"That worked! Thank you Richard. Leaving the Topic Type empty fixed it — DMs between regular users are now being scanned.
I’m now planning to set up two separate automations:
One for public posts with a strict moderation prompt
One for private messages with a lighter prompt — flagging only the most serious violations (CSAM, drug dealing, weapons)
This way public content gets full moderation while private conversations have more appropriate boundaries."
the topic can be closed. THX!
Hmm “all topics” does seem a little unclear in this context… maybe we should update to clarify
  • all topics topics (all categories)
  • Public Topics (exclude all secure categories) topics (public categories only)
  • personal messages only
The “All Topics” part made me think all content would be reviewed.
I didn’t even consider that leaving the field blank would result in all content being reviewed.
I think having a single dropdown is pretty limited and three separate options would be better and definitely more clear to a user.
  • public topics yes/no
  • non-public topics yes/no
  • private messages yes/no
There are 8 possible situations and the drop down only covers four of them.
maybe so ?
  • All ( topics + pm )
  • public topics only
  • non-public topics only
  • non-public + pm
  • private messages only
That does not cover “regular topics ( both public and non-public), but no PM’s” which would be a pretty logical choice.
And, albeit a less likely choice, “public topics, and PM’s”
