Hi there,
I’ve just upgraded the DO server on which my Discourse forum is hosted from a 1GB instance to a 2GB instance.
Then I changed the the app.yml file to use 3 unicorn_workers instead of 2. (Anything else I should increase to speed up the forum?).
Now, I want to run: ./launcher rebuild app - However, I’m afraid it would change admin settings and or reset the entire discourse install? Would it?
It might be a dumb question, but I never worked with Docker.
Best,
Dylan
