Não bumpie tópicos quando uma ação de moderação for editada
As of right now, if the last post on a topic has been edited, it will bump it, great, that’s okay. What I find quite annoying is that if I do a moderation action towards a topic, for example, closing, and I edit the lock reason, it will automatically bump the topic. I think that any post that isn’t a moderator action that has been edited, should bump the topic. But, any moderator action that has been edited shouldn’t bump the post
Use the topic level admin wrench to reset the bump if needed.
2 curtidas
Ah okay, I don’t see this because I’m only Leader.
2 curtidas
This brings up a good point, @zogstrip can you assign this task so that TL4 users can use the “reset bump date” function? That seems quite safe to me and gives TL4 more oomph.
5 curtidas
Thanks, that will be useful for me on a couple of websites when editing wiki / “How To” topics and other documentation topics.
3 curtidas
Done. FEATURE: Allow TL4 users to reset bump date · discourse/discourse@c309961 · GitHub
6 curtidas
I wonder if I can be sure. According to the code, everything should work, but strangely, TL4 users do not see this tool. Version:
3 curtidas
It should be in the admin wrench. I forgot to change it in the composer. I’m fixing that right now.
FIX: "Toggle topic bump" wasn't visible for TL4 users · discourse/discourse@dc477d1 · GitHub should make it work everywhere.
6 curtidas
This topic was automatically closed 24 hours after the last reply. New replies are no longer allowed.
