I just received this notification on my discourse how to fix?
The
download_remote_images_to_localsetting was disabled because the disk space limit atdownload_remote_images_thresholdwas reached.
A notification was received indicating that the download_remote_images_to_local setting was disabled due to the disk space limit being reached. To resolve the issue, users can try clearing up more room on the server or changing the download_remote_images_threshold setting. Alternatively, running ./launcher cleanup can help clean up space by deleting Docker containers that haven’t been running for 24 hours.
For more extensive cleaning, codinghorror suggests running the following commands via SSH:
apt-get autoclean
apt-get autoremove
git pull
./launcher rebuild app
./launcher cleanup
This can help fix the issue by cleaning both Docker containers and old Ubuntu automatic kernel upgrade archives. AdamCapriola confirms that these steps helped reduce disk space usage from 90% to 57%. codinghorror assures that these commands are still valid and safe to run. Enabling a CDN or configuring uploads to S3 may also help alleviate disk space issues.
The
Either clear up more room on the server or change the threshold in the settings.
You can try running ./launcher cleanup to clean up space.
where can I fond the threshold settings?
is this safe? what does it do? does it just give space or delete things?
also where do I do this?
allow animated avatars
Allow users to use animated gif avatars. WARNING: run the avatars:refresh rake task after changing this setting.
It will delete any docker containers that haven’t been running for 24 hours.
It is safe to run if you don’t use docker for anything else and your Discourse installation is running.
To run avatars:refresh, SSH into your server and run:
cd /var/discourse
./launcher enter app
rake avatars:refresh
I just got the disk space limit message. I’ve been periodically cleaning up old Docker containers but my available disk space has simply depleted over time.
Is the only solution to upgrade my droplet (on Digital Ocean)? My memory usage seems fine; it’s just a disk space issue. Seems overkill to move up to their next plan. Would enabling a CND or configuring uploads to S3 help?
log in via SSH and
apt-get autoclean
apt-get autoremove
git pull
./launcher cleanup
That should fix you up nicely, cleaning both Docker containers and cleaning up old Ubuntu automatic kernel upgrade archives too, which can be quite large over a year.
Thanks! The really helped. Went from 90% to 57% disk space used. Should be good for a while now. ![]()
¿Esto sigue siendo relevante y seguro de ejecutar?
Sí, estos comandos siguen siendo válidos.
