Spurious warning about downloading remote images?
I just upgraded to 2.4.0 beta 11, and quite shortly afterward received a warning that:
The download_remote_images_to_local setting was disabled because the disk space limit at download_remote_images_threshold was reached.
However, when I checked my admin console, it would appear I have 4.8 GB of free space. Any idea what happened (bug in b11?), and if there’s any harm in turning download_remote_images_to_local back on?
Thanks!
Have you checked the setting download_remote_images_threshold? It is clearly not a spurious warning unless the setting kicked in too early.
If it is 10% and you have 50GB of storage then it will stop when your site hit 5GB free.
Most likely this will help:
Doh! You’re of course likely right.
That was a big help, thank you! Gigabytes saved.
