תוצאות ה-Dropdown search box מתאפסות כעת לאחר לחיצה על תוצאה אחת?
Hi there, I was wondering if the recent change in the dropdown search box behavior was intentional or accidental? It used to remember the query and the results after clicking on a result, and it did a soft load of that topic page, and then clicking on the search icon again showed the same search results immediately, making it much faster to look through a bunch of search results. Now on my recently updated forum and on Meta it requires hitting <Enter> again to bring the results back, and I’m pretty sure it runs the search query again too.
Here’s a Discourse forum that hasn’t been updated yet, because it still has the older search drowdown behavior that I prefer:
https://forum.tuxdigital.com/
5 לייקים
This is happening on my forum also, it’s annoying when you’re trying to collect a lot of posts in one thread.
2 לייקים
Thanks @rahim123 for raising this :slight_smile:
This was not an intentional change of behavior. I will take a look at fixing it next week.
4 לייקים
Awesome, thank you!
לייק 1
I have submitted a fix. Should be merged soon :slight_smile:
https://github.com/discourse/discourse/pull/25504
4 לייקים
Excellent, thanks very much!
לייק 1
