Hello,
I wanted to try and fix a one row of JavaScript code in Discourse but could not dare submit a PR without making sure I did not break anything or making sure it did really fix the problem.
So I found what was said to be the easiest way to start a Discourse dev env up: VAGRANT.md.
In there I read:
Getting Started
- Install Git: Redirecting… (or GitHub for Windows if you want a GUI)
- Install VirtualBox: Downloads – Oracle VirtualBox
- Install Vagrant: http://www.vagrantup.com/ (We require Vagrant 1.7.2 or later)
- Open a terminal
- Clone the project:
git clone https://github.com/discourse/discourse.git- Enter the project directory:
cd discourse
So I followed steps 123 (I already have git and cloned a fork of discourse on my Windows laptop) and installed Virtualbox for my Windows then Vagrant for my Windows.
Until I realised, well:
- Are those steps starting from Vagrant installation shouldn’t have been done from inside Virtualbox?
- My Virtualbox is just empty, what OS should I put here?
- Why install git before Virtualbox if it should be inside?
I am confused.
I have done three first steps but fourth step tells me to open terminal. In Virtualbox? Which VDI?
I must be even dumber than what was expected making those easy dev env install docs.
Are there some official pre‐installed VDI image? Like this seemingly outdated image?
Should the doc have been interpreted as following?
Getting Started
- Download and open this or that VDI file (which contains this or that installed OS with git)
- Install Vagrant from inside VirtualBox: http://www.vagrantup.com/ (We require Vagrant 1.7.2 or later)
- Open a terminal from inside VirtualBox
- Clone your fork of the project:
git clone https://github.com/yourname/discourse.git- Enter the project directory:
cd discourse
From my point of view (for my low level abilities), some steps were missing. ![]()
I have read both the “Discourse as Your First Rails App” blog post and its comments as well.
