So I do this vagrant up, but nothing happens. Then I simply downloaded the discourse.box by itself and added vagrant add discourse file.box and it unpacks it, thereafter nothing happens anyway. I’ve imported the vmdk into virtual box, and it quits.
It was designed to frustrate people, right?
sam
(Sam Saffron)
3 Aprile 2018, 10:47pm
Vagrant is pretty abandoned, use one of the other guides:
This tutorial has been tested on Windows 10 and 11.
To set up a development environment for Discourse on Windows, you can do it using Windows Subsystem for Linux feature.
This setup requires the WSL 2 installation. It is only available in Windows 10 builds 18917 or higher. We’ll assume that you already installed Windows Subsystem for Linux 2 (Ubuntu) on your Windows 10 system. WARNING: Install Ubuntu 18.04, and not 20.04 since some installations will fail on 20.04. For m…
I wanted to do a post (that I try to keep up to date) with notes about my current dev environment.
This was a setup I WAS using, I no longer really use it I develop on Linux native. This setup though is reasonable if you are on a Windows machine.
My building blocks
Windows 10 creators update
Wsltty which I prefer built in bash for windows console
VMWare workstation with latest Ubuntu installed
Mobaxterm cause its nice to have an X server
Vim plus my vim setup installed inside th…
schleifer
(Andrew Schleifer)
4 Aprile 2018, 8:20pm
3
Would it be worth the time to bring vagranting up-to-date?
If not, here’s a PR to rip it out.
https://github.com/discourse/discourse/pull/5737
zogstrip
(Régis HANOL)
4 Aprile 2018, 8:51pm
4
We might want to re-work this post as well.
Update April 4, 2018 The Discourse Vagrant development install is not longer supported and maintained. Current development install guides can be found at meta.discourse.org for Windows, macOS, and Ubuntu.
Yes who can re work that post? @jomaxro ?
jomaxro
(Joshua Rosenfeld)
5 Aprile 2018, 12:34am
6
The post is already updated. Per @sam I added an “update” section at the top explaining that the Discourse Vagrant development install is no longer maintained, along with links to current guides for Windows, OS X, and Ubuntu.
