¿Editar publicación vía API sin subirla?
I’m batch editing posts (custom import) and I’d like them to not bump the topic they’re into (if they’re last post in the topic).
Passing the post[updated_at] parameter to the /posts/{id}.json endpoint seems ignored. Is that the case? Is there any way to do it?
Edit: the endpoint is /t/[topic_id]/reset-bump-date
There is a reset bump staff action on the topic in the wrench menu. You’d need to send that command after edit.
6 Me gusta
