I’m not sure what it’s called, but I do know what it looks like:
I’d like to set this to NEVER appear. If I can’t have that, I’d like it to appear once in the entire lifetime of a user. As it is set now, it shows up twice in every single category.
This should only appear two times in the lifetime of every user, on their first and second replies.
(There is a similar advice panel for creating new topics, which would also appear twice in the lifetime of every user – the first and second time that the user creates a new topic.)
I don’t know if this is disable-able but you can certainly change the copy on it as needed via Admin, Customize, Text.
I think there might be some bugs around staff users on this education panel, then, but I’m pretty confident a regular user would only see it twice in their lifetime.
However, there are two versions of this education panel..
one for new replies
one for new topics
as the advice for creating new topics differs a bit from the advice for creating a new reply.
No repro, but I’ve also encountered this (with an admin account) on one of my sites. It’s not my account, but one I impersonated during setup due to SSO restrictions), so I never cared enough to investigate further.
