Email in stopped working... halp šŸ˜•
Today, @smcalear informed me that emails she was sending to our Discourse instance were no longer showing up.
I checked some things out and found the following:
  1. Nothing I know of changed on the system between when it was working (12 noon) and when it was observed to no longer be working (12:30 pm)
  2. The emails are being sent to the correct address ourforum+categorything@gmail.com
  3. The gmail inbox we’re using for email in is still being polled successfully.
    It is set up to ā€œarchive emailsā€ after they are accessed via POP, and indeed, the emails in were getting archived.
  4. https://ourforum.com/admin/email/received does not show any of the new emails
  5. https://ourforum.com/admin/email/rejected does not show any of the new emails
  6. https://ourforum.com//logs does not show anything suspect
Any ideas about what could be going on or where to look next?
Any ideas here @zogstrip?
Is or was something forwarding email to the Gmail account? Could something have broken there?
No, this is just me sending emails directly to the account… and I can see that the emails are being accessed (since they are being archived).
Looking into this more and here’s some more info:
I logged in and grepped through the logs in rails/production.log, but didn’t see anything.
I tailed that file and sent 4 more emails. 3 of them worked, but 1 did not. I copied and pasted the subject and body of the failing one to a new email and that worked. So it does not seem to be content related.
I’m looking in lib/email/processor.rb and it seems like failures should be logged via the log_email_process_failure method in most cases.
But I see now that there is a log_mail_processing_failures site setting which is disabled by default.
Turning that on now and sending more mails to see if a new failure shows up in any logs…
Update: got one more failure, but still don’t see anything in any logs…
:facepalm: D’oh, I found the problem…
I set up a ā€œstagingā€ site a few weeks ago to test another migration. I restored a backup there and made notes to turn off certain settings (like outgoing email). But I did not turn of the POP3 polling there for incoming email.
Sure enough, I see all the ā€œmissingā€ emails listed there on the ā€œreceivedā€ and ā€œrejectedā€ email tabs.
I will go ahead and turn off the polling there (and update my notes)
Thanks for rubber ducking this with me everyone! :baby_chick:
(cc @smcalear)
