Email nella casella di messaggi?
Is it possible to configure Discourse so that I have an email address @ my Discourse domain which goes to my message inbox on Discourse?
Groups can be assigned email addresses to start new conversations, but not users. Discourse isn’t a replacement for a conventional mail server/client.
That’s sort of true, but support@discourse.org gets delivered to a group.
Sure, but discourse.org is hosted at Google, not Meta. I’ve never had cause to email it, but it’s either a group which distributes mail to users, a mailbox which is accessed by multiple users, or an alias to a mailbox which is delivered by pop3 to a Discourse category or group inbox, right?
@rkaplan is asking for an email address at his discourse domain which goes to his mailbox. User mailboxes don’t support mail aliases, which is why I said that groups could have mail aliases, but not users.
Nice, I didn’t know about this feature. For others who have a hard time finding it:
  1. Enable config setting “email in” under “☰ → Admin → Settings → Email”.
  2. Go to “☰ → Admin → Groups → <choose group> → Manage → Interaction” and set “Email: Custom incoming email address”.
    (This setting is not visible before enabling “email in” in the previous step.)
If the OP wants the email to message inbox feature only for a few users (say, staff members), it will be acceptable to configure it manually for each of these users. Then, the above technique together with groups with one member only are a suitable option.
The “custom incoming email address” of each group can still be set in format “Discourse username @ my Discourse domain”.
È interessante notare che questo funziona:
  1. Creare un nuovo gruppo admins_messaging in Discourse
  2. Quando le email in arrivo sono abilitate, questo gruppo può essere contattato direttamente tramite un indirizzo email piuttosto complicato ma comunque funzionante: ourdomain+admins_messaging@discoursemail.com
Tuttavia, tentare di ingannare il sistema inviando un’email al gruppo admin esistente a questo indirizzo non funziona:
ourdomain+admins@discoursemail.com
C’è un modo per inviare email dall’esterno ai gruppi admin o moderator?
Se non è possibile, c’è un modo per reindirizzare/inoltrare i messaggi ricevuti dal gruppo admin_messaging creato al gruppo admin?
