:discourse2: אימוג'י אינו קיים באינסטנסים אחרים
סיכום מבוסס בינה מלאכותית
The :discourse2: emoji is not available by default in some Discourse instances. nathank discovered this issue while Oneboxing and found that it renders nicely in meta, but not in their own instance. JammyDodger suggested adding it as an image, but this didn’t work as intended. Falco explained that only official Unicode emojis are shipped with Discourse, and custom emojis can be added by admins. nathank found the settings to add custom emojis in /admin/customize/emojis and suggested updating an old emoji blog post.
This is a teeny weeny bug, probably related to :discourse2: being bespoke or something. It would be nice to have it in the default emoji sets though in other instances. We like and refer to the mothership quite often!
I discovered this when Oneboxing.
It renders nicely here in meta:
But not in mine:
3 לייקים
FWIW, I find this idea appealing. :slight_smile: I just tried a workaround of adding it as an image instead, but that got pulled out as the onebox thumbnail so didn’t really work as well as I’d hoped.
3 לייקים
We only ship official Unicode emojis in Discourse, and leave for admins to add their custom emojis easily in the web interface.
4 לייקים
No space to slip a cheeky bit of branding in? :slightly_smiling_face: Maybe a special little something for the admin guides, etc?
3 לייקים
It has taken me years to finally stumble across how to do this!
The settings are in /admin/customize/emojis, and the documentation is here:
This isn’t surfaced very easily in a search for emoji (for example, add emoji). You can only change the search priority by category, not by tag eh?
Also, I wonder if this old emoji blog post should be updated:
2 לייקים
