Il balzo di Emojii verso il basso
STEPS:
  1. open editor window (via reply or New Topic)
  2. create several lines of text until it’s longer than the visible window height
  3. scroll back up so the end isn’t visible
  4. click somewhere in the visible text and type “:” to begin the emojii process
  5. select one (either in the immediate list or from the “more …” list)
RESULT:
The screen pops down to the end.
MORE DATA
The blinky cursor stays where you were typing. You are just no longer seeing that part of the post anymore.
This problem started recently (like past couple weeks maybe?).
The problem was just confirmed on a completely different OS and browser. (so fairly confident it’s not “just me and my weird computer world”)
I know, I know, the “real” solution is to stop adding emojii’s while editing a post. LOL
:star2:
Hi,
no repro with your steps for me. Can you repro on try.discourse.org please ?
3 Mi Piace
I am reproducing it on try.discourse.org.
I was also reproducing it on
party.michellebasey.com (still in Trial land)
community.sethgodinfanclub.com
and 2 of Seth’s workshops
:sunny:
hmm …
It doesn’t happen unless the text is taller than the viewable editing window.
If I type
adf
adf
adf
adf
adf
adf
adfa
dsfa
sdfasdfdsfa
enough times to get a scroll bar
then use my mouse rolly wheel to go back toward the top, then type : and select an emojii … that’s when it happens
if I fully type the name of the emojii, all is well
hmmm …
1 Mi Piace
I can repro here on meta
4 Mi Piace
I’m seeing it with @ as well, (hopefully a “shared code” kind of problem).
1 Mi Piace
Ok finally got why I wasn’t getting a repro, it only “works” if you click on emoji with the mouse, not when you select with Enter
Investigating…
3 Mi Piace
This should be fixed by:
3 Mi Piace
Note: we should really move mention autocompletion stuff from composer-editor to d-editor. It’s kind of unexpected, emojis and categories are in d-editor and mentions in composer-editor
3 Mi Piace
This topic was automatically closed after 2 days. New replies are no longer allowed.
