Enable Push Notification generates error
Hello,
On the latest 06e1af2b1d
Repro:
  1. Go to Notifications
  2. Enable Notifications (The success notification not arrive)
  3. Check console
By the way the notifications seems to also works after this.
Error in console:
If i uncheck this option on meta :arrow_down:
Screenshot 2021-05-29 at 10.33.09
Then the success notification arrive successfully and the console is errorless.
Thank you! :slight_smile:
I can reproduce this, taking a look at it.
Looks like a regression introduced at
https://github.com/discourse/discourse/pull/13156
This here should fix it
https://github.com/discourse/discourse/pull/13293
This topic was automatically closed after 12 hours. New replies are no longer allowed.
