E-mail verzenden mislukt, uiteindelijke fout: fout - einde van bestand bereikt
Mail Sending Failed, Final Error: Error - end of file reached
Installation
Refer to this article for installation instructions.
I had a 1p instance first and then installed the forum, but I freed up ports 80/443 in advance.
Error
The email information displayed in the admin backend is:
Popup when sending failed:
(Cannot provide, I can only upload one image, but the content of the error popup is Error - end of file reached)
Additional Information
I used a 163 mailbox with SMTP directly. Many people suggest using an email address with my own domain, but we are a bit poor.
I remember that the 587 TLS of NetEase mailbox had some issues* (the original system used 465 for sending mail, I think there’s some reason for that)*.
I modified some parts of the configuration file by searching for information and using AI, mainly these parts:
DISCOURSE_SMTP_ENABLE_SSL: true
DISCOURSE_SMTP_ENABLE_START_TLS: false
DISCOURSE_SMTP_AUTHENTICATION_TYPE: login
app.yml Configuration
## this is the all-in-one, standalone Discourse Docker container template
## After making changes to this file, you MUST rebuild
## BE *VERY* CAREFUL WHEN EDITING!
## YAML FILES ARE SUPER SUPER SENSITIVE TO MISTAKES IN WHITESPACE OR ALIGNMENT!
## visit http://www.yamllint.com/ to validate this file as needed
templates:
  ## Uncomment the next line to enable the IPv6 listener
  #- "templates/web.ipv6.template.yml"
  - "templates/web.ssl.template.yml"
  - "templates/web.letsencrypt.ssl.template.yml"
## which TCP/IP ports should this container expose?
## If you want Discourse to share a port with another webserver like Apache or nginx,
## see https://meta.discourse.org/t/17247 for details
expose:
  - "80:80"   # http
  - "443:443" # https
params:
  db_shared_buffers: "2048MB"
  #db_work_mem: "40MB"
  #version: tests-passed
env:
  LC_ALL: en_US.UTF-8
  LANG: en_US.UTF-8
  LANGUAGE: en_US.UTF-8
  UNICORN_WORKERS: 8
  ## Required. Discourse will not work with a bare IP number.
  DISCOURSE_HOSTNAME: bbs.furina.chat
  ## Uncomment if you want the container to be started with the same
  ## hostname (-h option) as specified above (default "$hostname-$config")
  #DOCKER_USE_HOSTNAME: true
  DISCOURSE_DEVELOPER_EMAILS: 'images8023@163.com'
  ## TODO: The SMTP mail server used to validate new accounts and send notifications
  # SMTP ADDRESS, username, and password are required
  # WARNING the char '#' in SMTP password can cause problems!
  DISCOURSE_SMTP_ADDRESS: smtp.163.com
  DISCOURSE_SMTP_PORT: 465
  DISCOURSE_SMTP_USER_NAME: phantasm_ai@163.com
  DISCOURSE_SMTP_PASSWORD: "(security token)"
  DISCOURSE_SMTP_ENABLE_START_TLS: false           # (optional, default true)
  DISCOURSE_SMTP_DOMAIN: 163.com # (required by some providers)
  DISCOURSE_NOTIFICATION_EMAIL: phantasm_ai@163.com
  ## If you added the Lets Encrypt template, uncomment below to get a free SSL certificate
  LETSENCRYPT_ACCOUNT_EMAIL: images8023@163.com
  ## The http or https CDN address for this Discourse instance (configured to pull)
  ## see https://meta.discourse.org/t/14857 for details
  ## The maxmind geolocation IP account ID and license key for IP address lookups
  ## see https://meta.discourse.org/t/-/173941 for details
  #DISCOURSE_MAXMIND_ACCOUNT_ID: 123456
  #DISCOURSE_MAXMIND_LICENSE_KEY: 1234567890123456
volumes:
  - volume:
      guest: /shared
  - volume:
      guest: /var/log
## Plugins go here
hooks:
  after_code:
    - exec:
        cd: $home/plugins
        cmd:
          - git clone https://github.com/discourse/discourse-solved
          - git clone https://github.com/discourse/discourse-reactions
run:
Suggest changing your email. Lark International has a free quota of 15,000 emails per month. Check out my post. If you have any questions, feel free to discuss them here.
https://starorigin.net/t/topic/218
