Errore 500 come risolvere?
Docker Manager: AGGIORNAMENTO FALLITO
#<RuntimeError: RuntimeError>
/var/www/discourse/plugins/docker_manager/lib/docker_manager/upgrader.rb:210:in `run'
/var/www/discourse/plugins/docker_manager/lib/docker_manager/upgrader.rb:101:in `upgrade'
/var/www/discourse/plugins/docker_manager/scripts/docker_manager_upgrade.rb:19:in `block in <main>'
/var/www/discourse/plugins/docker_manager/scripts/docker_manager_upgrade.rb:6:in `fork'
/var/www/discourse/plugins/docker_manager/scripts/docker_manager_upgrade.rb:6:in `<main>'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/railties-7.0.8.1/lib/rails/commands/runner/runner_command.rb:43:in `load'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/railties-7.0.8.1/lib/rails/commands/runner/runner_command.rb:43:in `perform'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/thor-1.3.1/lib/thor/command.rb:28:in `run'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/thor-1.3.1/lib/thor/invocation.rb:127:in `invoke_command'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/thor-1.3.1/lib/thor.rb:527:in `dispatch'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/railties-7.0.8.1/lib/rails/command/base.rb:87:in `perform'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/railties-7.0.8.1/lib/rails/command.rb:48:in `invoke'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/railties-7.0.8.1/lib/rails/commands.rb:18:in `<main>'
internal:/usr/local/lib/ruby/site_ruby/3.2.0/rubygems/core_ext/kernel_require.rb:37:in `require'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/bootsnap-1.18.3/lib/bootsnap/load_path_cache/core_ext/kernel_require.rb:30:in `require'
bin/rails:18:in `<main>'
Avvio di 3 worker Unicorn che erano stati fermati inizialmente
Ho ricevuto questo errore, come posso risolverlo?
Stai eseguendo un .launcher rebuild app dalla riga di comando o stai aggiornando dall’interfaccia utente? Se quest’ultima, potresti provare la prima?
Ho appena aggiornato discourse dalle impostazioni :frowning: non dalla riga di comando
Penso che una ricostruzione manuale dovrebbe risolverti. :crossed_fingers:
Sembra che non sia possibile eseguire questo aggiornamento dall’interfaccia utente e che Discourse_docker non debba tentare un aggiornamento. Ho riscontrato problemi in due siti durante l’aggiornamento e questo è almeno il secondo che vedo qui dall’ultima versione.
Penso che David abbia aggiunto un messaggio adesso:
