Errore nella conversione dell'immagine
How to hide full path disclosure in error message?
{“failed”:“FAILED”,“message”:“/discourse/lib/upload_creator.rb:210:in `execute_convert’: An error happened when converting from PNG to JPG.”}
How overwrite methods in Discourse::Utils.execute_command ?
Sorry, what are you reporting here? I don’t understand.
I want to override this method
That’s what I wanted to do
 def self.execute_command(*command, failure_message: "")
  Rails.logger.warn("this is plugin!!!")
  stdout, stderr, status = Open3.capture3(*command)
  if !status.success?
    failure_message = "#{failure_message}\n" if !failure_message.blank?
    if Rails.env == "development"
      raise "#{caller[0]}: #{failure_message}#{stderr}"
    else
      raise "#{failure_message}#{stderr}"
  stdout
This is not really Discourse-related but more Ruby-related. I suggest you properly learn Ruby with online courses before you continue writing plugins for Discourse.
