Error on invite, internal server error
I sent an invite to a friend and he is getting an internal error. Any place I can see logs for the background on this issue?
Also when trying to sign up at talk.newpathconsulting.com there’s an error during sign up. No matter what email I use I get “this email is already in use”. Anyone seen this before?
Here’s an info on an error that was close to the timing of the error
Message (3 copies reported)
NoMethodError (undefined method `token=' for #<EmailToken:0x00007fe0b9b72810>
Did you mean?  token_hash)
app/models/email_token.rb:9:in `block in <class:EmailToken>'
app/models/user.rb:1480:in `create_email_token'
app/models/invite_redeemer.rb:73:in `create_user_from_invite'
app/models/invite_redeemer.rb:123:in `get_invited_user'
app/models/invite_redeemer.rb:87:in `invited_user'
app/models/invite_redeemer.rb:167:in `approve_account_if_needed'
app/models/invite_redeemer.rb:91:in `process_invitation'
app/models/invite_redeemer.rb:8:in `block in redeem'
app/models/invite_redeemer.rb:6:in `redeem'
app/models/invite.rb:193:in `redeem'
app/controllers/invites_controller.rb:274:in `perform_accept_invitation'
app/controllers/application_controller.rb:399:in `block in with_resolved_locale'
app/controllers/application_controller.rb:399:in `with_resolved_locale'
lib/middleware/omniauth_bypass_middleware.rb:71:in `call'
lib/middleware/anonymous_cache.rb:356:in `call'
config/initializers/100-quiet_logger.rb:23:in `call'
config/initializers/100-silence_logger.rb:31:in `call'
lib/middleware/enforce_hostname.rb:23:in `call'
lib/middleware/request_tracker.rb:187:in `call'
Backtrace
activemodel (6.1.4.1) lib/active_model/attribute_methods.rb:469:in `method_missing'
activesupport (6.1.4.1) lib/active_support/callbacks.rb:427:in `instance_exec'
activesupport (6.1.4.1) lib/active_support/callbacks.rb:427:in `block in make_lambda'
activesupport (6.1.4.1) lib/active_support/callbacks.rb:179:in `block (2 levels) in halting_and_conditional'
activesupport (6.1.4.1) lib/active_support/callbacks.rb:604:in `block (2 levels) in default_terminator'
activesupport (6.1.4.1) lib/active_support/callbacks.rb:603:in `catch'
activesupport (6.1.4.1) lib/active_support/callbacks.rb:603:in `block in default_terminator'
activesupport (6.1.4.1) lib/active_support/callbacks.rb:180:in `block in halting_and_conditional'
activesupport (6.1.4.1) lib/active_support/callbacks.rb:512:in `block in invoke_before'
Env
HTTP HOSTS: talk.newpathconsulting.com
I believe that issue was because the database had been migrated for an upgrade but disk space made it impossible to launch the new container.
@asirota if it’s working now, mark this as the solution.
